FCP333
Oct 25, 2023Tutor
Change subnet on IOT VLAN to 172.32.50.203
I have an Orbi Pro WiFi6 . I need to connect my solar panel inverter to the IOT VLAN network, but the Inverter has static IP address of 172.32.50.203, from a previous router
To change the inver...
- Oct 26, 2023I changed the ip address range of VLAN4 to the 172.32 etc, plugged the inverted into a port linked to VLAN4 and it works fine
Oct 26, 2023Guru - Experienced User
Why not set a static IP address on a laptop to same subnet accept for last octet to something different, long enough to connect to this device and set this device to what you have on the Orbi system or may set it to Dynamic IP address configuration so the device can connect to any router or any DHCP IP subnet?
FCP333
Oct 26, 2023Tutor
- FCP333Oct 26, 2023TutorPS
Thanks for help! - FURRYe38Oct 27, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
