FCP333
Oct 25, 2023Tutor
Change subnet on IOT VLAN to 172.32.50.203
I have an Orbi Pro WiFi6 . I need to connect my solar panel inverter to the IOT VLAN network, but the Inverter has static IP address of 172.32.50.203, from a previous router
To change the inver...
- Oct 26, 2023I changed the ip address range of VLAN4 to the 172.32 etc, plugged the inverted into a port linked to VLAN4 and it works fine
