Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
CrimpOn
Nov 23, 2023Guru - Experienced User
When a web browser complains "not safe" about the Orbi SSL certificate, I search for that tiny link near the bottom of the screen called "Advanced Options" (or something vague like that) and get to a choice of "go there anyway". Once the browser has been instructed to ignore the SSL certificate, it usually quits complaining about it.
Rillekille
Nov 23, 2023Guide
I don't get that far...
After clicking "Advanced Options" I just get an empty page with the text below:
- CrimpOnNov 23, 2023Guru - Experienced User
So, the task is to figure out "what is different?"
On my Windows 11, Chrome version 119.0.6045.160, clicking on the Advanced button brings up this page:
- RillekilleNov 23, 2023Guide
I'm running Chrome 120 beta, maybe it's a change in version 120?
I don't login very often on the router so I really can't tell how long it's not been working.- RillekilleNov 23, 2023Guide
We don't get the same error message, mine is ERR_SSL_KEY_USAGE_INCOMPATIBLE.
