Zworkon
Nov 22, 2023Aspirant
Chrome Certificate
After the latest updates with chrome, The certificate is not secure and I get this: This site can’t be reached The webpage at https://192.168.x.x/ might be temporarily down or it may have moved ...
- Nov 22, 2023
Here is the solution I found:
We found a fix. Delete the user's local state file located in C:\users\(username)\AppData\Local\Google\Chrome\User Data\Local State. After deleting it the issue went away. Let me know if that works for you.
EDIT: Confirmed this is also happening on MacOS. Need to go to Library/Application Support/Google/ and Delete the Local State file from their as well.Thanks Everyone.
CrimpOn
Nov 23, 2023Guru - Experienced User
So, the task is to figure out "what is different?"
On my Windows 11, Chrome version 119.0.6045.160, clicking on the Advanced button brings up this page:
Rillekille
Nov 23, 2023Guide
I'm running Chrome 120 beta, maybe it's a change in version 120?
I don't login very often on the router so I really can't tell how long it's not been working.
- RillekilleNov 23, 2023Guide
We don't get the same error message, mine is ERR_SSL_KEY_USAGE_INCOMPATIBLE.
- CrimpOnNov 23, 2023Guru - Experienced User
Could be. Doesn't give me much of an incentive to load up the beta version.
With MS Edge 119 it's possible to bypass the warning and login to the router.
I have an update waiting for Edge so if it is version 120 coming maybe I won't be able to login with that browser either efter the update...
