skrid216
Sep 13, 2023Aspirant
Combining 2 Orbi Pro systems
I believe I know the answer to this, but for some reason, I still think it should work the way I want it to. I have two Orbi Pro systems, original SRR60 router with 4 satellites. In the hopes of...
Sep 13, 2023Guru - Experienced User
If the FW version is the same across all units, and you use the 1st SRRs web page to add new SRS process, the SRR should see the 2nd set of SRS. I'd do this with the 2nd SRR turned OFF.
Possible limited on how many SRS can be added to the SRR? 4 is pretty good.
How big is this home or building? Sq Ft.
