Boatguy54
Jul 10, 2024Guide
Complete IOT security and access solution Orbi 6 Pro
Skipping all the tech talk, I just want to know how to configure the system to achieve this using default Netgear VLANS 10: Admin 20: Employee 30: IOT 40: Guest 1) Employee network can reach ...
ErwinL
Sep 02, 2024NETGEAR Moderator
Hello Boatguy54
And welcome to the NETGEAR Community! 🙂
Forgive me if I need to clarify the IOT VLAN part. So the IOT VLAN should be accessible by employees but the same IOT devices should not have communication between IOT devices themselves in the IOT VLAN?
Have a lovely day,
Erwin
Netgear Team
Boatguy54
Sep 02, 2024Guide
Correct
- ErwinLSep 05, 2024NETGEAR Moderator
Hello Boatguy54
May I know how many are wired and how many are wireless for IOT devices?
Have a lovely day,
Erwin
Netgear Team- Boatguy54Sep 06, 2024Guide
All are wireless.
- ErwinLSep 08, 2024NETGEAR Moderator
Hello Boatguy54
Since all IOT are wireless, you can prevent them from reaching each other through client isolation feature of our access point. For access between emplyee and IOT you will need to apply access list or ACL between the two VLANs. You may check the link below for an example of ACL configuration. How many ports do you need for wired devices for employees VLAN?
Have a lovely day,
Erwin
Netgear Team
