Boatguy54
Jul 10, 2024Guide
Complete IOT security and access solution Orbi 6 Pro
Skipping all the tech talk, I just want to know how to configure the system to achieve this using default Netgear VLANS 10: Admin 20: Employee 30: IOT 40: Guest 1) Employee network can reach ...
Boatguy54
Sep 02, 2024Guide
Correct
ErwinL
Sep 05, 2024NETGEAR Moderator
Hello Boatguy54
May I know how many are wired and how many are wireless for IOT devices?
Have a lovely day,
Erwin
Netgear Team
- Boatguy54Sep 06, 2024Guide
All are wireless.
- ErwinLSep 08, 2024NETGEAR Moderator
Hello Boatguy54
Since all IOT are wireless, you can prevent them from reaching each other through client isolation feature of our access point. For access between emplyee and IOT you will need to apply access list or ACL between the two VLANs. You may check the link below for an example of ACL configuration. How many ports do you need for wired devices for employees VLAN?
Have a lovely day,
Erwin
Netgear Team- Boatguy54Sep 16, 2024Guide
Erwin - No wired access for employees is needed.
Thank you.
