12carpenoctem
Apr 19, 2021Aspirant
Connecting SRR60 to Comcast Business Gateway and Unmanaged Switch
We recently purchased the Orbi Pro SRR60 mesh router with 3 satellites to extend the WiFi coverage in our small business. We have a cable modem (Comcast Business Gateway), an unmanaged switch (Netgea...
Apr 20, 2021Guru - Experienced User
What gateway are you using?
You're saying it has wifi which indicates that its own routing functions.
cascading routers is a recipe for issues (like you're running into)
https://kb.netgear.com/30186/What-is-Double-NAT
what you put router #2 in line, what router is that?
12carpenoctem
Apr 20, 2021Aspirant
I ended up resetting the router one more time using the Modem -> Router (Router Mode) -> Switch configuration. It took several minutes to come back online. Once it did, internet via the WiFi was working, but the wired computers on the switch still did not have internet access.
I ended up changing the DHCP range to 10.0.0.1/24 and then the wired devices were able to connect to the internet as well.
I've discovered that it takes a significant amount of time (sometimes over 5 minutes) for the Orbi Pro to completely reboot. I'm not sure if this is normal or not. I think part of my problem was I wasn't waiting long enough and kept interrupting it before it was completely online.
As for the double NAT thought, I was thinking the same thing at first. But what was unusual is the devices could all communicate with each other (wired and wireless), just internet connectivity was limited. In my previous experiences with double NAT, the internet usually still works, but there will be communications issues between devices because they're on separate networks (as well as issues with port forwarding).
Hopefully the current configuration will continue to work. Then I need to just figure out the best positioning for the sallites.
- JohnD333Apr 20, 2021Apprentice12car....
Remember that once you reposition satellites you will encounter a yet to be addressed problem. Upon reboot for any reason (loss of power, reboot, firmware update, most reconfigurations) the satellites reboot long after the main unit finishes its reboot. All of your distant WiFi devices that were connected to a satellite will lock onto the router and will not switch to the appropriate satellite unless they move around. Most WiFi things that don’t move (pc’s, printers, speakers, cameras, roku’s, thermostats, tablets that do not move, etc), particularly those that are more than a year old will be stuck with a poor connection to the main unit. Those devices will need to be power cycled off then on in order to find the stronger satellite signal. Some WiFi devices only need WiFi to be switched off then on if that is an option.
For that reason alone, do not set firmware to automatically update, or perform any remote reconfiguration, reboot or or firmware update unless you have someone on site to power cycle the WiFi devices that need to connect to a satellite for a strong signal.
Happy networking.
John
