natallica
Jul 18, 2019Initiate
Considering returning Orbi Pro SRK60
Hi everyone - I'm hoping someone can help me. I bought a 3 pack Orbi Pro a little over 2 weeks ago and am seriously considering returning it and wanted to ask for advice on last ditch things ...
- Aug 07, 2019
Thanks for your answer Josh. Sorry I was upset, but I've been really upset many times since I installed the Orbi system. Anyway, I checked back in this communtiy for answers and found another critical guys post about netgear and you guys trying to support us. Of course it's better for all of us if we can solve the problems instead of just hating.
I will contact you with the serial nr. I already have put in the number in my account and tonight I clicked on "activate" so I think you can see my number, but I will message you anyway.
I'm not really sure it's just the satellite causing my problems with the wifi disconnecting, but something between the router and the satellite is wrong. Or just the wifi in general from the router (and then satellite of course). We have connected apple-tv, a desktop computer, arlo pro and some other stuff by cables from the router and this stuff works (in general). So we get internet from the router but the wifi is disconnecting. I don't know how the router and the satellite is synchronized but when they disconnect I also loose the connection to the stuff connected with cables from the satellite.
The thing I would like to know is, where should I start and which steps should I follow? I have read the manual, and have tried to do like it says. I don't want to read the manual anymore, it did'nt work for my system. If someone can write down the steps I should try or send me a link with basic instructions I will give it a try again. Thanks for your time.
OrbiRon
Jul 29, 2019Aspirant
I bought this useless **bleep** for over a year ago, the Orbi Pro Business WiFi System, I only have one satellite though. Router SRR60 and SRS60 - firmware V2.3.5.108. I should have returned it back while I had the chance!!
But we had new internet fiber installed in the house and thought it was trouble with the new internet connection so we continued contact the Internet provider. Every f*cking day we lost wifi. Since our neighbours did'nt complain on the fiber we finally started to blame the Orbi Pro System. I hate spending time on setting up things again and again, but since my wife complained about the wifi and tried to fixed this in the weekend everything died. So I had to start from scratch, turn off all power, disconnect cables, reset the fiber modem, reset the router and satellite, update firmware, connect everything. When I finally had done all steps I could'nt find the wifi name in the list.. it had renamned the SSID to something else, so it took some time to realize our wifi was working under another name. Anyway, I could rename it and everything seemed to work. It worked the rest of the sunday, amazing!! So I connected the NAS, started to backup devices and so on. I was happy for about one day, til this evening and the satellite disconnected and started to mess up the wifi again. Now the satellite is powered off, and I'm using the wifi(!) from the router.
I'm so angry because all trouble we have had with the wifi, when this **bleep** was supposed to be one of the best wifi-systems for small business. When I checked the invoice it was like one week over the warranty, which was one year from the store. So YES, if you still have the opportunity to send your system back and get the money back - DO IT! I'm fed up with this. Nothing helps!
As a note I want to tell that I also have the Netgear Arlo Pro system (cameras). Something went wrong with the installation to, so I was close to return the cameras. (I had the older Arlo system, working all good, but I had to buy expensive batteries so I bought the new Arlo Pro). Anyway, I reinstalled everything and the Pro system started to work and have worked since then. But this Orbi Pro **bleep** seems to be totally useless crap which can't be fixed!
MrJoshW
Aug 07, 2019NETGEAR Employee Retired
In regards to the satellite disconnecting. How often until the satellite disconnects? It may be an issue with the satellite and I would recommend having a case opened with support on this issue so we can further troubleshoot the device disconnecting. Please send me a private message with the Orbi Pro router's serial and I can have a case opened with support to determine the cause of the issue.
- OrbiRonAug 07, 2019Aspirant
