wrottier
Jul 19, 2023Tutor
Creating WAN failover
I'm trying to create a WAN failover, as the cable internet connection from my ISP fails occasionally. Currently I have the following set up. As a modem I am using a Fritzbox 6690 cable modem, which i...
wrottier
Jul 21, 2023Tutor
So far, no luck to get it up and running smoothly 🥴 I've searched in different forums and on Youtube, but so far I can't find an explanation on how to set it up with an existing router such as the SXR80 in between it. The SXR80 doesn't seem to accept the WAN connection from the Edgerouter X. I'm under the impression there's an IP conflict somewhere, now its the challenge to find out where the IP conflict is 😅
Jul 21, 2023Guru - Experienced User
Not sure what you mean by the sxr in between it. The sxr should be at the end of the chain. After the edgerouter.
One benefit is that the edgerouter sounds new and ubiquiti has been known for solid support. Might contact them about getting the dual wan setup properly
