Andrew1918
Jun 04, 2022Aspirant
devices not connecting to satellite( SXR80)
Hi every I have placed the router on the first floor at front house,satellite downstair at the back ,which is 20 meters apart, The satellite is running ethernet backhaul . Most devices not connec...
Andrew1918
Router on up stair,satellie on down stair,they are 20 meters apart.
Bricks in the house.
Try different setting from the forum but doesn't work.
Regards
Jun 05, 2022Guru - Experienced User
Its the device themselves that decide whether to connect to router or satellite. Its not actually the router/satellite that decide it. Some devices tend to be "stickier" than others. You can try turning down the broadcast power if you think devices are picking up a certain device more than others.
