nordicman
Dec 19, 2023Aspirant
Enterprise Mesh on LARGE Residence
Hello, I'm looking for an enterprise solution for home use. The sky is the limit. I would like to create a mesh network for a home with an area of 15,000 square meters, approximately 20,000 square fe...
nordicman
I'd like to use wired connections but i'm limited. This is expensive residence.
We are using right now; FG + Fortiswitch POE + FAP's but we would like to change it for some more simply.
Anyway, these access points have not enough coverage and I would like to use something more powerful.
I heard that Netgear has some cool solutions.
schumaku
Dec 19, 2023Guru - Experienced User
Coverage can be enhanced by placing more access points - what requires cabling again.
Give them some time, WiFi 7 APs will certainly become available in Q1/2024. Yes, Netgear has excellent selection of switches and wireless access points ready to be deployed including Insight Management. Even the so new WiFi 7 router and the WiFi 7 based high-end Mesh system can only perform on a solid base - made up on MultiGig and 10 Gb switches.
Not much to argue against Fortinet - excellent enterprise grade firewall routers, switches, and wireless access points. Undoubted more complex to manage than Netgear Insight - at a much higher price point.
