100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
Mewohkie
Mar 03, 2024Tutor
So navigating to HKEY_LOCAL_MACHINE\SOFTWARE\Policies in regedit on my Windows11 23h2 machine and there is no \Google folder/path no chrome folder/path and under Microsoft, no Edge folder/path.
Manually adding them and then adding the registry values to them does not fix this either.
100won
Mar 03, 2024Star
Hi,
I tested in my laptop before posting here.
I usually use edge and chrome browser.
