100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
ReneD
Mar 11, 2024NETGEAR Moderator
Hello 100won,
And welcome to the NETGEAR Community! 🙂
This is already an ongoing issue and there is a patch firmware that fixes this. The official firmware is on its way but we do not have ETA on it. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided. After loading the firmware, a full factory default is necessary on the router, then you test if you can use Chrome or Edge after.
SXR80
SXS80
Take note to update the satellite firmware first before the router. You may want to check the link below related to your issue.
Have a lovely day,
Rene D
Netgear Team
