100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
Mewohkie
Mar 03, 2024Tutor
So navigating to HKEY_LOCAL_MACHINE\SOFTWARE\Policies in regedit on my Windows11 23h2 machine and there is no \Google folder/path no chrome folder/path and under Microsoft, no Edge folder/path.
Manually adding them and then adding the registry values to them does not fix this either.
MELGEAR
Mar 14, 2024Aspirant
Trying to enter the menu of the Orbi-Pro-router using Edge or Chrome can lead to the message:
It looks like the webpage at https://.... ight be having issues, or it may have moved permanently to a new web address.
If it is only about being able to enter the Orbi-menu of the Orbi-router, please use an alternative browser as a quick fix, for example: Firefox. That worked for me very well to ignore the error message and to enter the Orbi menu/interface.
- RillekilleMar 26, 2024Guide
Hi ReneD !
If there is a patch firmware for this issue I'm also in need for it.
Can you please refer me too?
Best regards
/Rickard Hökros
