100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
Rillekille
Mar 26, 2024Guide
Hi ReneD !
If there is a patch firmware for this issue I'm also in need for it.
Can you please refer me too?
Best regards
/Rickard Hökros
