100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
MartijnS
Apr 20, 2024Guide
Is there also a patch for the SRS60?
Chris_888
May 12, 2024Initiate
I second that, even if it's a end-of-life product, not being able to access the login page to configure the router settings make my router obsolete and un-usable. Orbi app lack to many advance setting that i require.
ReneD Please bring patch to SRR60 router and SRS60 satellite users. 🙂
Thanks
- schumakuMay 12, 2024Guru - Experienced User
DavidGo can you jump in here again please? If wally brain is right, you mentioned there is a build with a possible fox for the SRR60/SRS60/SRK60.
- DavidGoMay 13, 2024NETGEAR Expert
Sure schumaku, we have a patch for SRK60 models also.
MartijnS, Chris_888 , please find the firmware for SRR60, SRS60 and SRC60 below
SRR60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRR60-V2.7.3.100.zip
SRS60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRS60-V2.7.3.100.zip
SRC60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRC60-V2.7.3.100.zip
Thanks
DavidGo
- RillekilleMay 13, 2024Guide
ReneD Any patch for the RBK50?
Regards
/Rickard
