100won
Mar 03, 2024Star
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Google wrote: " Require X.509 key usage extension for RSA certificates chaining to local roots X.509 certificates used for HTTPS should contain a key usage extension that declares how th...
DavidGo
May 13, 2024NETGEAR Expert
Sure schumaku, we have a patch for SRK60 models also.
MartijnS, Chris_888 , please find the firmware for SRR60, SRS60 and SRC60 below
SRR60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRR60-V2.7.3.100.zip
SRS60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRS60-V2.7.3.100.zip
SRC60: https://www.downloads.netgear.com/files/GDC/BETA-FW/SRC60-V2.7.3.100.zip
Thanks
DavidGo
Rillekille
May 13, 2024Guide
ReneD Any patch for the RBK50?
Regards
/Rickard
- schumakuMay 13, 2024Guru - Experienced User
