cecltd
May 23, 2022Tutor
Firmware update for Orbi Pro SRK60
Hi, my company is using SRK60 (firmware version 2.5.2.104) and notice that the latest firmware is 2.7.1.108 on Netgear support page. However, when I check the web interface of my router, it says no ...
May 24, 2022Guru - Experienced User
Did you try manually updating it?
- cecltdMay 24, 2022Tutor
Thanks plemans
yes, I had updated the firmware manually to version 2.5.2.104. I think I could do it again to the latest firmware. But I just want to know if there is still notification for non-Insight users.
- plemansMay 24, 2022Guru - Experienced User
Even without insight, it should still update if its enabled.
I'd update it to the latest version and see if you can then enable auto-updates.
