django2020's avatar
django2020
Frustrated after V4.2.3.102 update
Router: SXR80
Satellite: SXS80
Firmware: v4.2.3.102
Problems:
1. Android play store is no longer able to download or update apps. Works when on Cellular or Work WiFi.
2. YouTube takes forever to load videos - on TV, Desktop, and Phones (iOS or Android) it's the worst. Works when on Cellular or Work VPN.
What have I done so far?
1. Reverted the router + satellite's firmware to the previous version
2. Confirmed that No services are blocked
3. Confirmed that No sites are blocked
4 turned off/reboot/tried again/turned on/reboot/try again
   4.1 Enable 20/40 MHz Coexistence
   4.2 Enable WMM (Wi-Fi multimedia) settings
   4.3 Enable MU-MIMO
   4.4 Enable Fast Roaming
So frustrated.
  • plemans's avatar
    Did it work better with the firmware downgraded?
    Did you try a factory reset?
    What modem/gateway is it connected to?
    • django2020's avatar
      django2020
      Nope hasn't worked after I have downgraded. Will try a factory reset next weekend. Will keep you guys posted.
ProSupport for Business
