BooJangles's avatar
BooJangles
Apprentice
Jan 27, 2021
FW 2.6.0.108 Deletes Address Reservations on Reboot
Performed update and lost all existing IP address reservations. Set them back up manually and will work until you perform a reboot and they are all lost again.
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi BooJangles
     Are you managing your Orbi Pro devices via Insight? Address reservation is supported from Insight so you can use Insight to configure address reservation.
    Thanks,
    Raghu
    • BooJangles's avatar
      BooJangles
      Apprentice
      Whether I use Insight or Browser when local the reservations delete after a reboot.
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Thanks BooJangles  for confirming. We are working on a fix for your issue. Will update you ETA as soon as we know.
        Raghu
  • Ditto for OrbiPRO Wifi6 (SXR80 SXS80)
    I believe that reservations worked properly (were kept on reboot) until the firmware update prior to 3.2.1.102, but not certain.
    With Wifi6, restoration from backup reserved IP’s are not restored - there is an empty reservation list.
    Does not matter if the IP reservation is made via Insight App, Incite portal on PC, or direct on browser web interface ____._____._____.1.
    Hope Netgear is working on this too.
    • RaghuHR's avatar
      RaghuHR
      NETGEAR Expert
      Hi all,
      We are workiing on this issue. Will keep you updated.
      Thanks,
      Raghu
ProSupport for Business
