r___o___b
Aug 18, 2021Aspirant
Guest network not working and admin portal slow (SXR80/SXS80)
The system has been working fine for several weeks but recently the connectivity has been slow (the speed tests are still showing about 700 MB download speed but even the admin login to the orbi admi...
DaneA
Aug 19, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly answer the questions below:
1. Are you able to go online via a wired connection just fine if you connect a PC directly to the LAN port of the SRX80/SXS80?
2. Are you able to go online wirelessly just fine through the main SSID?
3. Are there any changes made on the settings of the SRX80/SXS80 or any changes made on the network setup?
Go ahead and try to reboot the SXR80/SXS80 as well as you can update the firmware to the latest version and observe if the same problem will occur.
DaneA
NETGEAR Community Team
- r___o___bAug 25, 2021Aspirant
In answer to this:
1 - no I have not tried the wired connection (see the answers below).
2 - yes, the other wireless LANs are working OK. If I connect to any other wireless LAN (which are identified as an office (admin), Point of Sale and Other Point of Sale) I can connect just fine. I get an IP address, connect and am able to access the internet. Each of these Wireless LANs has their own IP scope and when I connect, I get an appropriate IP address for the that VLAN.
3. As for changes, no, the only change that would be affect this would be that the available bandwidth for the guest VLAN was changed from 40% to 25% of the total bandwidth. I do not know how to see the usage of the bandwidth per SSID so I cannot validate that something is being overrun. However when this issue is occuring, I have seen between 0-4 systems that have able to connect to the guest network.
I checked again tonight at the site and the guest portal was not allowing my device to connect. Again with simliar symptoms. The SSID was advertised. Sometimes my device would try to connect and I would get to the portal and I could enter the password but I would never fully connect and get internet access. Tonight (after changes which are listed below), I could not connect to this guest portal but the software showed that four (4) devices were connected.
Changes since last message:
- router and access point rebooted
- firmware update on the router and access points individually
- DaneASep 15, 2021NETGEAR Employee Retired
Let us try this. Kindly update the firmware of your SXR80/SXS80 to v3.2.6.102Hotfix. This firmware fixes security vulnerabilities. You can download it here. Then, check if the same problem will occur.
If the same problem will occur, I suggest you to open a support ticket with NETGEAR Support here at anytime. Kindly state your concern and you may include the link to this thread.
DaneA
- r___o___bSep 15, 2021AspirantSo I updated to that firmware version and I am still seeing the issue with the guest portal (the other SSIDs appear to be a bit more stable). Here is a list of other things that I tried to do to help out with this issue:
Changed the guest network to use the built in guest LAN (which is a /24 and is in the 192.168 range like the other SSIDs - I was previously using a 10.10.30.* IP range so it would be easier to identify guest users).
Setup email forwarding of the logs.
Changed the DHCP lease time of the systems in the guest network to less than 24 hours (I believe it is at 12 hours now).
On the known trusted good SSIDs (employee, iot), known devices were statically reserved to hopefully reduce DHCP requests.
None of these items appear to have fixed the guest portal issue.
When I look at the logs, I am not seeing DHCP run out of addresses (at most during a day on the guest network, I am seeing 20-30 unique IP addresses being handed out on the busiest days).
