BIG9MM
Apr 07, 2021Apprentice
Help please
1. I would like to know how to get alerts on the INSIGHT app when a device joins my network? I have the BR500, Orbi Pro Gen 1. 2. I have an Xfinity modem router and a BR500 with Orbi Pro and wou...
schumaku
Apr 08, 2021Guru - Experienced User
BIG9MM wrote:
Orbi Pro is in AP mode still . All is working great and I love the force safe search setting mode in the insight.
Great, so the BR500 is the only router active. Keep in mind that systems or switches wired direct to the BR500 LAN ports will bypass the Orbi Pro based Insight Content Filter. Said this: Netgear must bring the Insight Content Filter to the BR200/BR500, too. YeZ
BIG9MM wrote:
I had to do the same thing when I was playing around with OPENDNS.https://support.opendns.com/hc/en-us/community/posts/360071800412-rb500-netgear
Reviewed that, thank you.
The obvious difference (leaving the additional NAT alone) is that typical CPE in router mode provide their own LAN IP with DHCP, while in bridge mode the ISP does provide it's own DNS IPs by DHCP (resp the PPPoE counterpart where applicable on two wire xDSL). For the case where you implemented OpenDNS on the BR500 (along with an updater on the network), the two resp. three OpenDNS DNS IPs must be used and configured on the BR500. If these don't reach the Open DNS infrastructure, well possible the ISP does capture plain text DNS queries on the router, and redirect these to it's own DNS.
BIG9MM
Apr 09, 2021Apprentice
I took the Orbi out of AP Mode in directly running it as a router and it seems to be more stable.I’m not sure if there’s a conflict between the BR500 IP address with the ORBI Pro. Filtering works still the same by setting it up as a router or putting it in AP mode. Xfinity modem is still in bridge mode as that is the only way to make the filtering work. If you’re interested to do some remote connection and check out my settings perhaps we can work something out just p.m. me. Thanks for all your help and information it’s great value to the community to have individuals like you.
- BIG9MMMay 12, 2021Apprentice
Well, I took the plunge and bought the new Orbi Pro. I love now that I can segregate and isolate different SSID for example employees and local network can have their own printer without overlapping and seeing each other.
Thank you a million Netgear for this feature, even though I had a dish out more money.Now, they did an awesome job on isolating different departments with this new Orbi Pro router the only thing that they have to straighten out is the filtering system with NetGear Insight. I completely had to give up because there was no way that wants to filter system was on that I was able to view my cameras even though that there’s a space to put in the URL to bypass the filtering system nothing could work and on top of it I was filtering porn and it would filter shopping sites so unfortunately, I gave up on it for the time being. Hopefully, they fix everything because I would jump all over the purchase price of the filtering system.Basically what I had to do was use my BR500 and connect my new Orbi Pro and the older Orbi Pro to the BR500 and put inline a Firewalla Blue Plus to the older Orbi Pro to do all the filtering and now it seems to do the job and not block my Wyze cameras. As soon as they can get this filtering system on the Insight to work and not blocking my Wyze cameras then I’ll take the old Orbi Pro off line and buy the Netgear Insight filtering. It did not block my Ring cameras, just my Wyze cameras.
