sunflyhome
Jan 29, 2023Aspirant
High and Unstable Network latency on wired connection from SXS50 to main router SXR50
I have one SXR50 and 2 SXS50. From one SXS50, a desktop is connected via a cat6 cable to port 4. When I made a ping test to router, the network latency was extremely unstable. When I connected same d...
schumaku
Jan 30, 2023Guru - Experienced User
No doubts, an additional wired connection from the SXS50 to the SXR50 would provide a much better connectivity.
Hard to guess what impact this unknown wall has for the wireless backhaul. Well possible, either a weak 5 GHz channel is in use, or the probably well loaded and lower performing 2.4 GHz. Doesn't the Web UI provide more insight on the wireless backhaul connectivity?
sunflyhome
Jan 30, 2023Aspirant
There is a door actually always open. Wall is standard 2x4 with 1/2 drywall at both side.
UI doesn't provide any info about back haul performance
