sunflyhome
Jan 29, 2023Aspirant
High and Unstable Network latency on wired connection from SXS50 to main router SXR50
I have one SXR50 and 2 SXS50. From one SXS50, a desktop is connected via a cat6 cable to port 4. When I made a ping test to router, the network latency was extremely unstable. When I connected same d...
sunflyhome
Jan 30, 2023Aspirant
After I did factory reset on router. It seems the problem was gone.
In previous config,I enabled wireless 1,2,3. All of 3 have enabled separation of 2.4 and 5G. Bandwidth usage control was not enabled.
After reset, I didn't enabled wireless 2 and 3. Only wireless in active. I also enabled separation of 2.4 and 5G. 28ms max is acceptable and 2ms average are perfect.
I have no intention to enable wireless 2 and 3 for now. I used to like to have all of my Iot (sensors, cams...) use wireless 2 or 3. Due to the issue I had, It's not worthy spiting them.
Ping statistics for 192.168.1.1:
Packets: Sent = 300, Received = 300, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 28ms, Average = 2ms
sunflyhome
Feb 12, 2023Aspirant
After 1 day, the lagging issue came back. It's not about wireless segments at all. I found both of my satellites were using 2.4G as backhaul connection.
Here is what I tried to do based on https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/RBS50-Connection-Type-2-4Ghz/m-p/2236779#M134189
1. Lower 2.4G to 50% at Advanced wireless setup
2. Add a new SSID in wireless1 only for management purpose.
3. Move my general SSID to wireless 2 and enable VLAN to lot(30). I don't think most of y devices need to talk to each other.4.
4. Set all LAN ports at router and satellites to Access mode with Vlan default. I don't have managed switch at home.I only have wired devices asa gaming PC, ip phone and printer.
