BE2181
Mar 19, 2022Tutor
Home Setup
Using the above devices, I have set up my home system. The router and satellites are hardwired; however, the satellites do not appear as such on either the Insight app nor the webpage. On the Insi...
Mar 19, 2022Guru - Experienced User
are the satellites running through a switch?
Or are they directly wired to the router?
