BE2181
Mar 19, 2022Tutor
Home Setup
Using the above devices, I have set up my home system. The router and satellites are hardwired; however, the satellites do not appear as such on either the Insight app nor the webpage. On the Insi...
Mar 19, 2022Guru - Experienced User
are the satellites running through a switch?
Or are they directly wired to the router?
BE2181
Mar 19, 2022Tutor
The router feeds a switch. The satellites are plugged into sockets supplied by the switch.
- plemansMar 20, 2022Guru - Experienced User
what switch is it?
- BE2181Mar 22, 2022TutorAraknis 210 series web smart gigabyte switch AN-210-SW-R-8-PoE
- plemansMar 22, 2022Guru - Experienced User
Looks like a managed switch. Some people have reported issues on managed switches.
Does the same thing happen if you're using a unmanaged switch or if the satellites are direct wired to the router?
Never used the switch but if it has any igmp, disable it.
