BE2181
Mar 19, 2022Tutor
Home Setup
Using the above devices, I have set up my home system. The router and satellites are hardwired; however, the satellites do not appear as such on either the Insight app nor the webpage. On the Insi...
BE2181
Mar 19, 2022Tutor
The router feeds a switch. The satellites are plugged into sockets supplied by the switch.
Mar 20, 2022Guru - Experienced User
what switch is it?
- BE2181Mar 22, 2022TutorAraknis 210 series web smart gigabyte switch AN-210-SW-R-8-PoE
- plemansMar 22, 2022Guru - Experienced User
Looks like a managed switch. Some people have reported issues on managed switches.
Does the same thing happen if you're using a unmanaged switch or if the satellites are direct wired to the router?
Never used the switch but if it has any igmp, disable it.
- BE2181Mar 26, 2022Tutor
Well, in successive weeks, each of my SRS60 satellites have died. These items might be a year old, and they just stopped working. Had them plugged into surge protectors. One might have happened the day following a storm; however, its been snowing all day when the second one died. The green light on the back is on, indicating AC power. Unfortunately, no LED lights come on. The satellites are not recognized even when connected directly to the router with ethernet. Can't say that I'm ever going to plop down more money with Orbis. This seemed like a great system with the optional ceiling mount, which I need for my back patio. Back to the drawing board. Either different brand system or possibly just over to the Verizon 5G experience. Thanks for everyone's help
