jamesrleu
Dec 06, 2022Follower
how to configure igmp proxy on otbi toutrr?I need multicast support for my ipTV for this to work i r
I'm trying to get multicast to work soI can use my iptv thu TDs I need for the router to support igmp proxy. thrtr is a openwrt pakage of same name that i have used on other openrt deployments. can s...
Dec 07, 2022Guru - Experienced User
1. wow that is a challenge to read and I'm still not sure if I got it read. Read back through it and check your spelling a bit
2. what router do you have?
3. you're just needing iptv usage? Try this guide
and a post about it.
https://community.netgear.com/t5/Orbi/Orbi-satallite-for-IPTV/td-p/1950072
