bombermanfx
Oct 31, 2021Follower
How to tag vlan ID onto a WAN port with SXK30 orbi router
My current NBN provider TPG will require setting the VLAN ID to 2 on WAN port only. Do you know if the SXK30 can do this. This can be done set on consumer orbi routers but i cannot find anything similar in the SXK30 orbi user manual. Can you confirm this can be done?
Example... https://community.tpg.com.au/t5/Modems-and-Devices/TPG-NBN-with-Orbi-RBR50V2/td-p/40072
1 Reply
- BruceGuoNETGEAR Expert
Hi
1. Go to VLAN profile and a new profile with VLAN 2
2. In WAN port, select the profile.
See if this can resolve your problem.
