Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
Mstrbig
Feb 12, 2024Master
Hmmm… can't reach this page
It looks like the webpage at https://192.168.1.1/ might be having issues, or it may have moved permanently to a new web address.
schumaku
Feb 12, 2024Guru - Experienced User
Wait - do you have https enabled on your Orbi Pro SXK80 system?
Or have probably the Facebook Wi-Fi portal for the guest WiFi network enabled and active? Wireless > Guest Portal (Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual, p.109 ff.)
The special 192.168.1.1 URLs you listed before are plain http only of course?
- MstrbigFeb 12, 2024Master
No, but I'll try to access and double check.
- schumakuFeb 12, 2024Guru - Experienced User
Ref. the Facebook WiFi guest portal https://kb.netgear.com/000055556/How-do-I-set-up-and-enable-Facebook-Wi-Fi-on-my-wireless-access-point ... Meta is winding down this service, or has finally done it now. So this feature became obsolete from what I understand. plemans do you have some insights for a non-Orbi Pro owner like me? Have these controls be removed, or does everthing remain in place (without practical usage), and levaing any kind of side effects open?
