Pikadilli
Jul 16, 2026Follower
I have to adjust Port Forwarding but can't find the settings
I have a similar issue. Due to changes at work where they added ZScaler, I have to adjust Port Forwarding but can't find the settings
schumaku
Jul 16, 2026Guru - Experienced User
Port forwarding config is also available on Netgear Insight, certainly on the Insight Cloud portal:
https://kb.netgear.com/000065750/How-Do-I-Create-a-Firewall-Rule-in-the-Insight-Web-Portal
Pikadilli wrote:I have a similar issue.
Guess a moderator had split the discussion from the original thread, this made it impossible refering to the similar issue you had referred to
