dir
Mar 13, 2021Apprentice
Insight v6.1.15 on SRR60 v2.6.2.20 says satellite update available - but fails
Insight (v6.1.15/6.1.15.10) tells me that my satellite firmware needs to be updated, but fails. Router SRR60 V2.6.2.200 <--- current/latest f/w Satellite-1 SRS60 V2.6.2....
dir
I found another forum message mentioning that new (beta) f/w for the SRR60 and the RBS50Y (v2.6.2.200) is available, but it links to a message in the forum that's no longer available. I found a google cached page of the message and the links for the (beta?) firmware:
New Firmware V2.6.2.200 for SRR60/SRS60/SRC60/RBS50Y(for Orbi Pro) Now Available! [dated 2021-02-25 01:20 AM]
New Features:
This firmware provides the following new features:
- Supports the NETGEAR Insight app and Insight Cloud Portal version IM-6.1
This firmware addresses the following bugs:
- Fixes DNS issues that DNS request is hijacked when clients configure static DNS server
- 512 DHCP clients support in LAN setting
- Fixes wired satellite is showed disconnected in Insight webportal
- Fixes Orbi App support issue
- Fixes RBS50Y configuration reset issue. It requires to upgrade this firmware twice to fix the issue.
This firmware contains the following known issue:
After updating the router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
Download Link:SRR60 - https://www.downloads.netgear.com/files/GDC/BETA-FW/SRR60-V2.6.2.200.zip
SRS60 - https://www.downloads.netgear.com/files/GDC/BETA-FW/SRS60-V2.6.2.200.zip
SRC60 - https://www.downloads.netgear.com/files/GDC/BETA-FW/SRC60-V2.6.2.200.zip
RBS50Y - https://www.downloads.netgear.com/files/GDC/BETA-FW/RBS50Y-V2.6.2.200.zip
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from the local browser interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click.
Documentation:
On the product page. We highly recommend updating the satellite firmware first, and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
Additional Firmware Update Instructions for RBS50Y(for Orbi Pro):
The Orbi Outdoor (RBS50Y) uses different firmware versions depending on which wireless system you use. As of 2.3.5.22, RBS50Y detects whether the Orbi Router is an Orbi Pro system, and if so, automatically updates to Orbi Pro-compatible firmware.
If the firmware version is showing 0.0.0.0 on RBS50Y, the system is preparing to update to the Orbi Pro-compatible firmware.
I assume that there's a non-beta v2.6.2.200 f/w for the RBS50Y available somewhere, but neither it nor the v2.6.2.200 f/w for the SRR60 is listed in the Netgear Support pages for those devices, so I don't know where to download it.
