Milkysunshine
Oct 14, 2023Tutor
Insufficient passphrase length. It should be a minimum of 8 characters long.
I'm trying to simply disable SSID separation on my Wireless 1, and it give that error even though the password is 9 characters. I've tried on 3 different browsers and 2 different devices. It ha...
schumaku
Oct 14, 2023Guru - Experienced User
A little bit confused how this SSID separation ever was enabled for Wireless 1 (and as well for the Guest Network) - not an intended feature, making it an illegal combination:
- MilkysunshineOct 14, 2023TutorThey added it an a firmware update not too long ago.
- schumakuOct 14, 2023Guru - Experienced User
Nice find. Please check if the https://community.netgear.com/t5/Orbi-Pro-Beta/bd-p/en-business-orbiprobeta builds are correctly allowing this (in my personal opinion useless) feature.
If this isn't addressed, hnagaraju and DavidGo need to know and take care about.
