Myronm
Jun 24, 2017Aspirant
Invalid WPA Passphrase
I cannot connect my HP Laser Jet 475 printer to my Access Point. It shows the SSID but refuses to WPA Passphrase. I have made sure there were no spaces in the name and it still doesn/t work!
Hi Myronm,
Welcome to our community!
Have you tried using other network authentication from your AP? You can isolate it by using WPA2-PSK or try connecting it to other wireless network.
- JohnC_VNETGEAR Employee Retired
Hi Myronm,
- MyronmAspirant
I discovered that if i set the AP for WPA & WPA2-PSK, my printer connected right to it! Thanks!
