Milkysunshine
Oct 14, 2023Tutor
Insufficient passphrase length. It should be a minimum of 8 characters long.
I'm trying to simply disable SSID separation on my Wireless 1, and it give that error even though the password is 9 characters. I've tried on 3 different browsers and 2 different devices. It ha...
Milkysunshine
Oct 14, 2023Tutor
They added it an a firmware update not too long ago.
Milkysunshine
Oct 14, 2023Tutor
- schumakuOct 14, 2023Guru - Experienced User
Nice find. Please check if the https://community.netgear.com/t5/Orbi-Pro-Beta/bd-p/en-business-orbiprobeta builds are correctly allowing this (in my personal opinion useless) feature.
If this isn't addressed, hnagaraju and DavidGo need to know and take care about.
- MilkysunshineOct 14, 2023TutorI've had far too many issues with release firmwares. I'm staying FAR AWAY from beta firmwares.
SSID separation is absolutely not useless when you want to lock your 5ghz capable IoT devices to 2.4ghz, as well as many other use cases.
I guess you're not a fan of fine-grained control of your devices?- FURRYe38Oct 16, 2023Guru - Experienced User
Just ran my SXK30 series for about 10 days earlier this month:
My password is 8 simple all alpha lowercase for the main SSID. Been using this same PW for past 20 years.
