treasy
May 31, 2022Tutor
Intermittent disconnects using SXK80 in AP Mode with VLAN Tagging
Hello, I've been having a very frustrating problem with the orbi pros while in AP mode with VLAN tagging enabled. I have done some research and have narrowed it down to a few log messages that I see...
JamesJohnson
Dec 06, 2022Aspirant
Was this resolved and if so may I ask how ?
We're experiencing the same thing...
A single physical connection between our pfSense router and SXR80 in AP mode in trunk mode.
That physical connection carries a default VLAN (1, aka untagged) and 3 others (10, 20, 40).
These 3 VLANs are assigned to Wifi1, 2 and 3 respectively (all different subnets).
Clients are intermittently being dropped and the only message we can see at the time is
<6>Dec 6 14:15:12 kernel: br-lan: port 7(ath2) received tcn bpdu
<6>Dec 6 14:15:12 kernel: br-lan: topology change detected, propagating
Apart from the intermittent drop outs everything else is working fine.
justinhow1
Dec 11, 2022Aspirant
I am also having disconnection problems. Any news on this?
I have a 3 node 1 x SXR30 and 2 x SXS30 all system running V4.2.3.102. I have to reboot the WiFi Orbi's every two weeks or so as devices start dropping off the network. I am also using VLANs on the wifi network.
- justinhow1Jan 15, 2023Aspirant
FYI I back revved the firmware on all mt 3 SRX/SRS30 devices from V4.2.3.102 to V4.2.2.130 and the problem went away.
- hermesromerorJan 15, 2023Apprentice
Interesting, I might try that on my SXR80. Where did you get it? justinhow1
Thank you
- justinhow1Feb 23, 2023Aspirant
Sorry for late reply I did not get notofied of reply.
If you did not find it, all the old revisions are available on Netgear website where you get the latest.
https://www.netgear.com/support/product/sxk30b3.aspx#download
I can't say I have no problems (now running V4.2.2.130) with devices having trouble connecting to the WiFi but it is less requently.
Still wish you could schedule a reboot every x weeks.
