rsun0525
Jan 16, 2021Guide
iPhone and Android Orbi app won't detect my SXR80/SXS80's
I'm runing V3.2.0.108 firmware on router/satellites. I was not able to get both my iPhone and Android devices runing the Orbi app to detect the Orbi Pro. I had to find the IP address and just...
- Jan 18, 2021
Seems like the misunderstanding is my part, they said that the Orbi Pro can only be used with the Insight App, while only the Orbi can be used with the Orbi app.
rsun0525
Jan 17, 2021Guide
When I was messing with the Orbi RBR850/RBS850, it seemed like I could only get the Orbi mobile app to work if my mobile device was connected directly to the router, if it had connected to a satellite, I would get the same error. For the Orbi Pro SXR80, no matter what, router or satellite, same error for iOS, however, for Android, if I get my device on the router, the display seems to indicate it was going to work, but in the end it doesn't. Just thought this was an interesting behavior. I relate to to trying to use "orbilogin.com", when I'm not directly connected to the router. This doesn't seem to work on my PC unless I plug directly into the router or using the SSID from the router, etc.
rsun0525
Jan 18, 2021Guide
