racan's avatar
racan
Follower
Feb 11, 2020
Is the CBR40 compatable with SRS60 satellites?
I currently have the Orbi SRR60 router and (3) SRS60 Satellites configured with my AT&T Uverse internet. I am switching to xfinity and plan on buying the Orbi Tri-Band Cable Modem Router (CBR40) to save rental fees.
Is the CBR40 compatible with the SRS60 satellites? (I also have (2) RBS20 satellites if the SRS60's do not work))
  • racan,
    Welcome to our community! :)
    CBR40 can only be connected to Orbi and it is not supported by the Orbi Pro.
    Please close the thread by clicking the "Accept as solution".
    John
    NETGEAR Community Team
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    racan,
    John
ProSupport for Business
