sparks99
Nov 24, 2022Tutor
Is the SXK30 just as good as the SXK50 when using Wired Backhaul?
Is the SXK30 just as good as the SXK50 when using Wired Backhaul? From what I can understand, Orbi uses a dedicated wireless backhaul band that can't be used for clients even when someone uses on...
- Nov 26, 2022
I realized all the wireless devices on my network will be 2x2 and 80Mhz (or whatever is lower). So I can just save the money for now and upgrade down the road.
Just got the SXK30B3 delivered so will give that a go first. Technically I have the SXK50B2 on backorder as well but will probably end up cancelling that.
schumaku
Nov 25, 2022Guru - Experienced User
The user-facing wireless on the SXx30 systems have just an AX1800 access point each and 80 MHz bandwidth support on 5 GHz, in the wireless backhaul case sharing the AX1800 (1,200 + 600) Mbps with the wireless backhaul, typically 1,200 if the backhaul can be 5 GHz.
The SXx50 systems have AX5400 access points on each device including 160MHz bandwidth support on 5 GHz, for the AP part its a AX3000 system. In the wireless backhaul case, the AX5400 (600 + 2,400 + 2,400) Mbps system does reserve 2,400 if the backhaul can be operated 5 GHz. A lot more benefit IMHO.
