wnichols2's avatar
wnichols2
Issues with Orbi Pro SXR80 and SXS80
I recently upgraded my home wifi system to Orbi Pro 6, and it is working fairly well. However, I am having two main issues (which could be related). They are as follows:   Firmware Update: I am un...
  • DaneA's avatar
    Apr 07, 2021
    wnichols2,
    Welcome to the community! :)
    Let us try this.  Kindly follow the steps below:
    1. Download the latest SXR80/SXS80 Firmware v3.2.3.100 here.
    2. Disconnect your SXR80/SXS80 from the existing network.
    3. Manually update the firmware of the SXS80 then afterwards, update the firmware of the SXR80.
    4. Perform a factory reset on both SXR80 and SXS80.  Then, reconfigure the settings from scratch in order to start clean using the latest firmware version.
    5. Check if the SXS80 will connect via ethernet backhaul.  Observe if the same problem will occur.
    DaneA
    NETGEAR Community Team
ProSupport for Business
