Euiho's avatar
Euiho
MAC ACL settings are rolled back frequently.
I registered 10 wired devices in MAC ACL setting. (default policy: deny)
Those 10 wired devices had worked well.
After 13 hours, I registered one additional wired device.
After a while, 'Internet is not working!' someone yelled, and when I checked, some of the 10 wired devices disappeared from the list.
Problems with this pattern often occur. Is there any workaround or caution?
- I'm using one SRR60(2.5.2.104) and one SRS60(2.5.2.104)
  • Hi Euiho
    We have some known issues around MAC ACL feature when Orbi Pro detects more LAN devices. We can share beta firmware to you if this is urgent. Otherwise you can wait till next maintenance release. Tentative release date is around July-August time frame.
    Thank you for choosing Netgear Orbi Pro.
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi Euiho
    Raghu
    • Euiho's avatar
      Euiho
      RaghuHR , Thank you for the reply.
      I have another way using the insight L2 switch(but a little cumbersome).
      I will wait for the next release.:-)
ProSupport for Business
