Feb 14, 2022Guide
Mesh link status
Hello, I have the OrbI PRO Wi-Fi 6 mini model SXR 30 and two satellites SXS 30. I have them connected via ethernet backhaul. On the Insight app it shows the Mesh link status as excellent. Howeve...
7474
Feb 14, 2022Guide
Thank you for taking the time to reply.
I believe mine is running as intended as well and it is nice to hear that yours is showing the same and running as expected.
I have found that removing the Ethernet cable changes the link status to GOOD. With a return to excellent with reconnecting the Ethernet cable.
Just thought it used to show Ethernet prior to all of the firmware and app updates.
Thanks again.
Thanks again.
Feb 14, 2022Guru - Experienced User
I'm honestly not sure what it said before. I'm not a huge fan of the insight app as it takes so long to load so I rarely use it.
I mainly just log in through the gui
