Tabasco
Dec 13, 2017Aspirant
Need to extend wifi without ethernet cables
Our church is a large brick and block structure. It is extremely expensive to run ethernet so I'm looking at Orbi Pro as an option. Here is my current setup moving from ISP to users: Internet mod...
- Dec 14, 2017
Hi Tabasco,
Welcome to our community!
As per checking in here that you already have a WNDAP360 that supports point-to-point bridge feature so that you can place it anywhere you wanted as long as the signal is reached. No need to purchase orbi as you do already have a business AP.
Here is a reference for setting up wireless bridging(page 90).
JohnC_V
Dec 18, 2017NETGEAR Employee Retired
Tabasco,
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
Tabasco
Dec 18, 2017Aspirant
Yes, this is helpful information. I am curious, however, which models of Netgear access points I can consider that will work with the WNDAP360s that I already have. Is this model still active and available for purchase or has it been replaced with something that might be more powerful? I could install these along the hallway to get allow the signal to skip to the far reaches.
- JohnC_VDec 22, 2017NETGEAR Employee Retired
Tabasco,
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
