ankursharma1's avatar
ankursharma1
Follower
Oct 18, 2022
Netgear Orbi 6 Pro SXR80 - End device cannot search for SSID when configured with WPA3 Enterprise
I configured my Orbi Wireless 1 to WPA2 Enterprise. I connect my handheld device to Orbi SSID using WPA2 Enterprise (WPA2 PEAP security type). It gets connected, so my CA Certificate, Radius IP, Radius Port, Radius shared key are OK.
When I configure the Orbi Wireless 1 to WPA3 Enterprise, and use everything else same (CA Certificate, Radius IP, Radius Port, Radius shared) - my end device is not able to search or connect to the SSID.
NOTE: My end device supports WPA3 Enterprise (as I can connect it to WPA3 PEAP using a different brand Wifi Router)
Product: Orbi Pro AX6000 WiFi 6 Tri-band Router (SXR80)
1 Reply
  • Navigate to Wireless > Access control > Security. Select Enterprise with my RADIUS server. Set the WPA encryption selection as WPA3 only. Configure the RADIUS server.
