Sep 18, 2023Guru - Experienced User
New - SXR30 / SXS30 Firmware Version 4.3.2.102 Released
New Features: 07/22/2023
Adds another selection to the Transmit Power Control menu in router web interface so that you can lower the transmission output power for a radio.
Supports the 20MHz, 4...
Oct 03, 2023Guru - Experienced User
Going to update this with some info.
Mines been online for past 5+days and working well since I got this version of FW loaded.
System Uptime 05:23:26:41
I ran a speed test with a Asus GT-AX11000 connected in wirelessb bridge mode to the SXR30. I was surprised to see sub 100Mbps speed results for a 1GB/50Mpbs ISP service. LIke 60Mpbs on the down. 🤔
I then remembered that there was this feature seen under the debug page on the SXR and got it enabled:
After enableing it and giving it a minute or two as this seems to have changed the wireless configuration of course, devices disconnected then reconneted, and after the SXR wireless was back, I re-ran the same speed test again and now saw 373Mpbs on the down.
I would recommend users that have the SXK30 series system to enabled this feature to ensure your getting good wifi performances from the system.
- FURRYe38Nov 30, 2023Guru - Experienced User
FYI, new FW available:
