DavidGo
Apr 25, 2022NETGEAR Expert
New SXR80 / SXS80 Firmware Version 4.2.0.122 Released
New Features:
- Supports WPA2/WPA3-mixed mode in wireless networks 1 - 3
- Supports OWE in the guest portal
- Supports WPA2-PSK modes in the guest portal
- Supports WiFi scheduling
- Adds more satellite information to the satellite’s device UI
- Supports Insight Business VPN for wired clients connected over LAN ports
Bug Fixes:
- Fixes an issue where the NTP server can be blocked by ISPs in the U.S.
- Fixes a configuration conflict between Insight and Standalone settings
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Known Issues:
- After updating the router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite.
Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects. - WPA3-Enterprise might not work with iPhone 11 (supports 802.11ax) and above on iOS 14 and above.
Workaround: Do not use WPA3-Enterprise. - The device UI can be accessed via the default VLAN network only.
Workaround: Connect to a WiFi network that uses the default VLAN profile when you want to access the device UI. - When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, it is possible that the SXS30 satellite cannot ping the SXR80 router, and the bar LED lights magenta. However, clients can still access the SXS30 satellite and the Internet.
Workaround: Reboot the SXS30 satellite and the SXR80 router. - When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, wireless clients that connect to wireless network 3 with the VLAN feature enabled cannot access the Internet.
Workaround: Reload the wireless configuration or disable the VLAN feature on wireless network 3.
Download Link:
SXR80: https://www.downloads.netgear.com/files/GDC/SXK80/SXR80-signed-V4.2.0.122.zip
SXS80: https://www.downloads.netgear.com/files/GDC/SXK80/SXS80-signed-V4.2.0.122.zip
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from the local browser interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the satellite firmware first and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
