NicolasPXM's avatar
NicolasPXM
Follower
Nov 11, 2019
Options to Purchase Ordi AP - Full Mesh for Roaming
Hello  my name is Nicolas.
I need some help from you to choose the right Orbi Acess Point.
I need to purchase  ORBI AP for full mesh roaming for  our Office.
What is the best option I have ?
Also I need to know if  support LDAP or Radius authentication.
Thank you in advance
  • Hello,
    Currently we do not support radius, but it will be included in an upcoming 2.5 firmware release in mid December.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi NicolasPXM,
    Welcome to our community! :)
    Orbi Pro does only fit for a small office and it can only accommodate 40 wireless users. Unfortunately, it does not support LDAP and Radius Authentication. It would be better if you will check our wireless controller bundled with an Access point that is perfectly designed for your business.
    You may check it here.
    John
    NETGEAR Community Team
  • MrJoshW's avatar
    MrJoshW
    Hello,
ProSupport for Business
