smokeyonion
May 24, 2022Follower
Orbi AX6000 max number of satellites
How many satellites can be installed in a single Orbi AX600 (Orbi Pro WiFi 6 - SXK80B4) deployment?
May 24, 2022Guru - Experienced User
the official says 4 with good performance. You can add more but it might impact performance. Official says up to 6 with potential performance decreases.
How many satellites can you add to an Orbi WiFi System? | Answer | NETGEAR Support
I've seen more used but usually some are ran with a wired backhaul.
BruceGuo
May 24, 2022NETGEAR Expert
Hi
Orbi Pro is not same as Orbi product line. SXK80 can support up to 6 satellite.
Bruce
