cmj01
Feb 10, 2022Tutor
Orbi Pro - rather undewhelmed!
This query relates to SXR80 (router and 2 satelites) which doesn't appear on the model list above... Have just set this up and feeling a little bit underwhelmed. I've got it running as a rout...
Feb 10, 2022Guru - Experienced User
The Orbi Pro line doesn't offer amor as most business class setups have their own firewalls/protection and aren't in need of it.
If its something you want integrated into the router, the Unifi solution might be the better choice. (sad to say)
I've struggled a bit with all the "add on services" netgear has been selling lately like disney circle, premium parental controls, armor, and game boost. At a certain point, some of the features should be included on systems this expensive.
- cmj01Feb 10, 2022Tutor
Thanks for that.. What I was beginning to suspect. I liked the network segregation but I guess I could probably have implemented that on the home series?
Any recommendations for a good / cost effective firewall / threat detection system?
Many thanks,
Mike
- plemansFeb 10, 2022Guru - Experienced User
My home network isn't that complex or needing a ton of security so I make do with off the shelf antivirus/malware and a pi-hole with some aggressive blocking :)
I've tried the armor but found my solution worked better.
So I can't give you a decent business class recommendation. Sorry.
